MultiTester
16 years 4 months before #7179 by manual-mecanica
MultiTester published by Manual-Mecanica
What I would be interested in knowing is how to measure the pulses of the injectors and if you can measure the operation of the LAMDA zombda and the step by step. thank you
16 years 4 months before #7184 by manual-mecanica
Manual-Mecanica Answer Re: MultiTester theme
A meter in milliseconds can be measured but nesecitas, the multipunto works at 3.4 ms and the monkey point between 1.3 ms. The Landa probe is a current generator if you can measure it with a tester in milli volts that work from 200ml to 800ml, Occilando,: Laugh: and the step step by step you have to measure with a logic tip to know if the CPU generates the pulses for the step step by step has two entoces coils has 4 positive cables 2 and 2 negatives any other doubt ask me xD
16 years 4 months before #7189 by manual-mecanica
You can also use an LED to visualize if you get current to the injectors if that is what you want to check.-
