Hello friends: I hope you are having a good time, please if someone has the Mazda Demio Mazda Mazda Electric Manual 1997. I have problems with the distributor and the ignition module, I cannot identify the computer's response signal, and there is no spark in the spark plugs. Thank you.
Good afternoon friends: please, someone will have the Electric Manual of Mazda Demio 2007. I have problems at the distributor level and I fail to identify if it is the coil or the ignition module, since there is no spark towards the spark plugs and the computer was reviewed and it is good, I need to identify the computer's response signal to be able to perform the test to this system. Thank you.
