Hello everyone I have a problem with my Chevrolet C30; It is a truck year 1986, the mechanics is very basic, but days ago the clutch bombin of the bottom was damaged. Change the chit and the problem was complicated when the orquitable that holds the collar, ok, the box changed the clutch disc collarin, the press is fine! But today everything is and the clutch pedal is very hard and does not come down enough. What I have left is to change the bombin but I am not sure; I look for the manual of this car everywhere but nothing is difficult cotton !!
I hope you can help me! Grateful in advance Isidro
Hello Hisidro, you fixed that the press did not give the fan very flat, if this is the case they have to be hard, this can be resolved by putting some flat spicians after, between the press and bollant, not very wide because otherwise it will be clutch, well it is a test test or take it as a reference if it serves you, luck.
Humm hey I didn't look at that! you're right!!! Essa was one of my doubts at the beginning! The fan as the fan was closing it every time! But remember that when disarmament was quite tight until the end! What led me to squeeze it the same !!
I'm going to try first with the Bombin! because I honestly do not want to lower the box !!! If you do not solve with that or mode again !!!!!!!!! Thank you very much !!
