nuance 2000 with problems
15 years 7 months before #10182 by manual-mecanica
Matiz 2000 with problems published by Manual-Mecanica
Hello everyone, 2 week ago I bought a daewoo nuance year 2000 3 cylinders which 5 days ago I started to pull and I turned on the Ckec Engine which has not turned off my car started from bad to worse. Spark
That it may be I am super approved please if anyone knows please help me.
GREETINGSS THANKS
15 years 7 months before #10197 by manual-mecanica
Manual-Mecanica response on the Re: nuance 2000 with problems
Friend the easiest and most economical way is to make a scanner, you will save you to change things to change, the pulls is not only a injection problem and the one that goes out accuses a false or scarce air problem of this, you can have problems with the TPS that produces jaloneos but also does the MAP and the MAF, the irregular relief can be the IAC actuator or battery or temperature sensor. Check with a scanner that is my advice.
