You must bridge the Terminal A and B with a clip, you open the Ignition SW and the light a thousand will begin to flash the slower flashes are the tens and the fastest the units These codes are of 2 digits usually the one that always gives is the 12 that means that the engine is not turning the diagnosis connector must have a guide for the diagnostic connector and should be a square
