Hello friends I have a problem with the heater of Seat Ibiza 96 1.9 D the heater do not walk until after taking out a fuse and putting it again if someone passes by help please. Thank you
Look, I don't know how to refer to your fault but the preheating are at the beginning of air admission and only serve to level the air and have an adequate temperature to move on to the combustion camera
I would first check if the cable of the heaters arrives will have to arrive the battery tension, if you arrive then you will have to disassemble and check them one by one, abandoning that where the cable goes the tension and the dough takes it by contact with the cylinder head, when they check them, you will see if they get to the living red they are well if they do nothing of anything changing them. all the best.
