Electric failure 307
15 years 7 months before #10559 by manual-mecanica
307 electrical failure published by manual-mecanica
Hello, I would like someone to help me, I have a 307 of the year 2001 and before with the battery of home sometimes I was blocked when I started because in my opinion it seemed that the battery gave little power to the engine of starting. Issuer but after a while lets you work or sometimes or work throughout the Tallecto. The truth I would like to tell me where I could find electrical schemes to be able to find failures or if someone knows this problem because I will make me a hand please. Thank you very much greetings
15 years 7 months before #10585 by manual-mecanica
Manual-Mecanica Response on the Re: Electrical Failure 307
Apparently the radio is disrupting, if you flash the lights of the changer of the discs you can have made to lose, the only way is that you approach a technical service to make you a scanner and see if it can be programmed.
greetings:)
15 years 7 months before #10603 by manual-mecanica
Check the radio lands and the connection of the antenna that is a land by Ecensia that reveals your problem
