Hydrausian noise in my Kia Carens
15 years 7 months before #10582 by manual-mecanica
Hydraúlicist noise in my Kia Carens published by Manual-Mecanica
Do I have noise the bug in the engine of my Kia Carens, has anyone suffered them? As they have solved it? Give me ideas ..
Slds
15 years 7 months before #10604 by manual-mecanica
Manual-Mecanica response on the re: noise of hydraúlic taques in my Kia CaS
If they are tis what you can approach is to add an additive to the oil to increase its biscocity if the noise decreases the only solution is to change taquis, the noise that the noise can try from piston pins or pistons first you must cheacr from where it tries the noise.
15 years 7 months before #10621 by manual-mecanica
The noise is not constant only occurs when I accelerate around 1500 rpm, with loading the engine that is only when walking. It can be another component.
15 years 7 months before #10631 by manual-mecanica
If it does not sound with the vehicle in a clear neutral that is another problem, because in neutral at 1500 it sounds?
15 years 1 month before #13378 by manual-mecanica
This noise only happens with the vehicle running, when I accelerate. Can it be a injector seat? since in the utlim
