Hyundai Atos Gls
15 years 6 months before #10681 by manual-mecanica
Hyundai Atos Gls published by Manual-Mecanica
Hi Compis, yesterday I change the spark plug cable and I saw that one of them has been loose but the car hiba well. Now when putting them new, the car is strength. Why is it? What mess I have
thanks
15 years 6 months before #10707 by manual-mecanica
Manual-Mecanica Answer Re: Hyundai Atos Gls theme
Hello friend, what do you have or rather what year is it? The cable you found loose where was it? loose but put on the spark plug? If so, it is very likely that you have to change them. B)
15 years 6 months before #10726 by manual-mecanica
Heeeeee Cheka The order of ignition
: Laugh:
15 years 6 months before #10994 by manual-mecanica
If as the cumba tells you the order of teaching is 1-3-2 chao
15 years 5 months before #11017 by manual-mecanica
Check if you left any loose connector or if you let go without any connector the order should be 1-3-4-2 and check the spark plugs, greetings, I could be or rather check if you left any loose emptiness hose.-
