Frontier Turbo Diesel
15 years 6 months before - 15 years 6 months before #10805 by manual-mecanica
Frontier Turbo Diesel published by Manual-Mecanica
Hello friends:
I am from Venezuela and I have problems with my frontier and the fault it has is that it has no strength in the start and does not move, it only reaches 80 km/h. I have already changed filters, there are no leaks or air inlets to the fuel system. This has ever happened to them. That could be. Thank you very much to all
friends for your attention. Well, my frontier is the year 2007 Motor 3.0, does not turn on any warning light on the board and does not yield any fault code. Thanks again, we are in contact.
Last edition: 15 years 6 months before by .
15 years 6 months before #10818 by manual-mecanica
Manual-Mecanica Answer on the Re: Frontier Turbo Diesel
Friend you would have to give some more data to know what happens to you, as an example that engine has, if algina light on the board, etc. From what it seems does not accelerate because you have the center in emergency due to some injection probma.
15 years 6 months before #10832 by manual-mecanica
More information please. Does it throw fault codes? What model etc. Greetings.
15 years 6 months before #10839 by manual-mecanica
If you have a flowmeter, it may be that it fails and is not regulating the air flow.
All the best.
15 years 6 months before - 15 years 6 months before #10929 by manual-mecanica
Friend thanks for your attention. Well, my frontier is the year 2007 Motor 3.0, D22 Turbo Diesel. It does not turn on any warning light on the board and does not yield any fault code. Thanks again, we are in contact.
