Hello friends
, I am new in the forum and I would like to know Sialguien with more experience can help me, I have a mesubishi straw or montero diesel that the consequence sold as 2001, has a Diesel engine 2.8 without turbo and it is the work version (manual glass etc.), I also look that the back of the back is a little taller than the others that I have seen, with respect to this vehicle I have two doubts
. 2001 when it is more similar to those of the second generation or that of the 1998 model only than with a higher roof ..sess this other version of the straw or will have continued to draw old models along with the newest models someone knows something of this model in particular?
2. Everything with the car is going well, only that in the ma; Ana is a bit hard to teach after the whole day is normal, check with a mechanic engine and pump compressions and apparently everything is fine, change the oil and put Castrol for diesel for recommendation of the mechanic, but apparently everything remains the same. In the ma; Ana to teach it the shock button to increase the motor revolutions a bit this normal practice and of common use in the vehicle or this button has another application and I can be causing a day; or the future to the vehicle. If so, other alternatives I can try to solve my problem.
