Hello everyone, I have a problem in my Seat Toledo car of the year 99,110 TDI, which turns on the chivato of the Airba and does not go out, I am unemployed and I have no money to go to the workshop, if some of you would give me a clue of what it can be, I would appreciate it very much, I am very worried about the subject, since I am afraid that I spend something in the car, I hope your answers.
Good afternoon, I tell you what it can be without knowing well the breakdown that indicates through the VASS? The most normal in these types of breakdowns is usually the wiring of the lateral airbag, the connectors that are housed under the seats, or the chamks of the belts, I recommend that you go through some workshop that passes the machine for diagnosis and communicate the breakdown it presents. If the breakdown it presents is that of the belts or the side airbag. The solution is very easy you just have to cancel the airbag installation connector or the pretensioner. You only have two connectors under the seat one that of the pretensor and the other of the seat airbag. Cut the cable and weld directly canceling the connector. I hope it can help you although it is a hypothesis since it can be more systems, I give you a small idea of the easiest and most cheap that can be. On the question of whether it can be dangerous to have the breakdown, the most serious thing that can happen to you is that if you have an accident you do not skip the airbag. If you need any other clarification to communicate it. Greetings
Thank you for the advice you have given me, it can certainly be of the belt because it is difficult for me to collect, I will not take it to the workshop to pass the diagnosis, thanks anyway.
