Hello, I am Oscar for several years and worked in the PSA group. I can tell you because of the indications that you can be a problem of lack of turbo's feeding. That the Turbo bars check with the diagnosis machine while walking with the car. Possibly you have a fissure in a turbo tube and that is not detected by the machine, also some microtubus of the electrovalve to the broken turbo, obstructed or loose, or even that you have a lot Admission collector (also by Carbonilla).
I hope it will help you or at least orientation
, Oscar.
