Probemite with my Twingo helps !!!
18 years 3 months before #1149 by manual-mecanica
Probemite with my Twingo helps !!! Posted by manual-mecanica
Good to all on these sides I write to see if they can get me out of the mess that I have with my twingo .... it is the following ....
the tacometer or velocimetro as they want to call it I stop working and I have no idea what I can be, I imagine it is a sensor or something ... if someone already happened to this and has some idea that I can help me I appreciate it ...
thanks in advance in advance
18 years 3 months before #1152 by manual-mecanica
Manual-Mecanica Answer on the Re: Probemite with my Twingo Help !!!
The veting of the Twingo is Digaital, isn't it?
If I think yes.
That happens:
- It does not move from 0 km/h
- or the account of the account does not turn on.
If it is the second, you should start taking a look at the fuses.
If it is the first thing you tell me if I tell you where the speed collector is and what plug it is.
Thus at first glance it seems like an economic unimportant. Or I think so
15 years 4 months before #11615 by manual-mecanica
Good afternoon.
I have exactly the same problem. I would like to know where the velocimeter connector is located.
Greetings.
15 years 4 months before #11621 by manual-mecanica
It goes on one of the sides of the gearbox, it is easy to change but loop when this sensor fails to be accompanied by the check on.
15 years 4 months before #11622 by manual-mecanica
of check Engine ....? Because if so, he has not shown me anything on the board. Anyway, today when I get home, I lift it and take a look to see.
Thanks Kikemec, I review and see.
