The engine not for
15 years 4 months before #11527 by manual-mecanica
The engine not for Manual -Mecanica
Quito the contact key and the engine is still running my car is a Renault Clio of 93 1.9d
15 years 4 months before #11573 by manual-mecanica
Manual-mecanica response on the re: the engine not for
Hello, check in the injected pump just above it carries an electric hostel if it is open, it makes that failure, make them open the contact and observe that it makes noise when closing it and tries it and tell me the result but I see you changing it.
I hope it helps you if I do not give me more data code and I will try to help you
greetings from Tenerife.
15 years 4 months before #11575 by manual-mecanica
I already imagined that it was the Electrovalvula of Pare and check it and effectively.
Thanks anyway
