VW GOL 2000 VIBRA DIRECTION EVEN IN LOW SPEED
15 years 3 months before #12185 by manual-mecanica
Manual-Mecanica Response on the Re: VW Gol 2000 Vibra Address even in low speed
It is likely that if without seeing it I can't tell you.
All the best:)
15 years 2 months before #12720 by manual-mecanica
Look at me with a sprinter to put the Aukilio forward and devised to the deformation of the roof (Fate brand) the steering wheel oscillated a lot that he had to lower a wheel to the bench to be able to handle no more than 30km/h say the state of the covers before that nothing passes the wheels go ahead and those from front Greetings
15 years 2 months before #12731 by manual-mecanica
You know, I also put the replacement wheel forward because I am new, when you tell me that they may changed my cover, you mean exactly, I don't understand the term covered, you would be so kind to explain to me : HUH:
15 years 2 months before - 15 years 2 months before #12758 by manual-mecanica
But they changed the rubber of one of the front wheels, fix if it continues to oscillate in gravel roads (ripium). Greetings since if it were a bearing, it would have to sound more when you correct it on the route if it were a semi -axis, the noise would have to be placed when placing it in the dead point. Greetings and I hope it serves you
Last edition: 15 years 2 months before by .
