DAEWOO LANOS INJECTION PROBLEM
15 years 4 months before #11862 by manual-mecanica
Daewoo Lanos Problems Injection Published by Manual-Mecanica
To ver if someone can help me,
I do not get injection pulses to the injectors so that I can open and thus pass the fuel, it is a Daewoo Lanos.
Actually comes pulses but very little just millivolts
I do not have the electrical scheme of the vehicle so it is difficult for me, the wiring part I have controlled and the pulley sensor works well because it sends me a spark sign.
What else can be .....
15 years 4 months before #11881 by manual-mecanica
Manual-Mecanica Response on the Re: Daewoo Lanos Injection Problems
Friend first try the fuses and masses before ruling out that it is the computer
15 years 2 months before #12700 by manual-mecanica
;) Hi, Yovany from Colombia; Verify wiring masses; exactly in the multiple of admission in the rear; Verify the correct state of the battery; The Synchronization Points of the Detada Correa .... Good luck
15 years 1 month before #13286 by manual-mecanica
The truth is that I have the same problem that the friend who says that the injectors arrives under the injectors already has been discarded time sensor sensor sensor of the minimum coil apparent Disarmed the branch of the electrical system but it does not occur even if the escape does not fail of any kind the computer is perfect if anyone knows how to help or has an opinion is important I am not a mechanic of Daewoo I am an industrial mechanical tornero but any opinion I will try to understand it
15 years 1 month before #13306 by manual-mecanica
Hello, for FGAVOR, tell us exactly what the vehicle failure is, because there is a particular case that happened to me days in this vehicle. My email is
