You have to disassemble the inferior part where the steering wheel goes, then the upper part, but a boil to take out the complete sheet you must take 4 anchor bolts the problem is that only two of these have a hub and the others are smooth from Sincelera or with a dremel make a line to take them out with a palette screwdriver, but hurt your key is encoded? If so, the problem increases.
