Please help
15 years 3 months before - 15 years 3 months before #12145 by manual-mecanica
Help why published by Manual-Mecanica
Gentlemen, I have a problem with a 1996 Dodge Neon since it cannot turn on, if you go but it does not start, we already check the harnes (wiring) maybe there was a problem because it was changed.
The vehicle went out of nowhere, and the position sensors were already checked (both)
could send me the electrical diagram to re -connect the cables?
Greetings and if you can advise me something much better, since it is urgent to be my car
thanks: Woohoo:
is a 1996 Dodge Neon, Simple Tree, 2.0 Automatic
Last edition: 15 years 3 months before by . Reason: Data was missing
15 years 3 months before #12284 by manual-mecanica
Manual-Mecanica Answer on the Re: please help
Hello friend, there are many reasons for your car to present that fault, the most common when changing the branch is that the connectors of the coil and the cams sensor have confused, this causes a short on the PCM, another reason is that the work voltage of the sensors (8 volt) is short. something. My email is ...
Greetings
