The start is lodged between the Bloke and its other outlet is inserted inside the gearbox, it fits the steering wheel, it can be in two places under the multiple of admission or under the exhaust multiple. They carry two or three bolts and two or three cables, remember to disconnect the battery before and Hojo that in Peugeot it can happen that when the battery disconnect, the airback light is turned on from the airback do not scare yourself if this happens.
