Subaru Legacy brakes
15 years 2 months before #12587 by manual-mecanica
Subaru Legacy brakes published by Manual-Mecanica
Hello, friends of the forum ... I would like to help me with this.
A month ago I was in my car (Legacy 93), and derepent in a braking, the pedal was thoroughly, I assumed that I had cut some pipes, but it was not so. The strange thing is what I later returned to normal. As detail I can tell you that the tank of the brake fluid went up more than normal and the wheel on the side of the co -pilot was too hot, well this makes me think that the brake cylinder is possible to aggravate, the fact is that the car now slows normal.
I would like to know if anyone knows what this was due.
Atte:
Hernan ..
15 years 2 months before #12603 by manual-mecanica
Manual-Mecanica Answer on the Re: Subaru Legacy brakes
The problem may be with the brake fluid or a bad bleeding of the system, which increases is not normal at all.
15 years 2 months before #12625 by manual-mecanica
Hello friend, that is usually a problem of the brake pump caused by wear of the buckets or garrisons, check it well and repair or change it if the chopped cylinder is, and as the fellow Kikemec says it is not normal to increase the level of the fluid, greetings. :)
15 years 2 months before #12633 by manual-mecanica
Thanks friends for your prompt response, I will check the bomb and tell you ...
greetings ..
15 years 2 months before #12947 by manual-mecanica
When the right wheel is heated to you, the brake fluid made bubbles and uploaded the boat level a little and the pedal went down, when the pedal cooled it was hard again, the problem you have in the right front brake clamp
