Hello, how are you: I have mounted some rear brake pads of a Fiat Stil Apparently everything was correct. Have you given the case? I hope your help, greetings.
Surely you have something wrong with the bombin in the stilos to recover the bombin you have to turn the piston one band to the right and the other on the left, a car that changed the brake pads in a workshop and had a tube to change a bomb
I believe that you have to bleed the system, it is poorly purged is the whole problem there is an air bubble there around, remember that you must bleed the 4 brakes not only the one you disassembled, and that it is done from the most Sercano to the pump towards the farthest,
