Hello if the disconnected injectors have only one of the two terminals is normal and if it has 2 positive when connecting it the same is normal by k there is a return of the 12 volts for the same injector when the computer will be closed the circuit to negative and the negative signal appears for a few seconds if it has a spark and not pulse there is k revise the cran
