Audi Coupe does not spark.
15 years 2 months before #13145 by manual-mecanica
Audi Coupe does not spark. Posted by manual-mecanica
Hello, I have changed the Curate Board of my Audi and now I do not spark and apparently everything is fine and before I reached, the engine is 2000cc 20v TRACION FOUR AND TYPE OF MOTOR NM A MANUAL WOULD BE OF GREAT HELP, THANK YOU, THANK YOU
15 years 1 month before #13222 by manual-mecanica
Manual-Mecanica Response on the Re: Audi Coupe does not give a spark.
First, the first thing, Czech fuses and relays, then reviews all the connectors that you have unplugged, usually the spark command is given by the magnet captor, depending on the year of the car, it can be commanded by the flow of the same Czech way these components and notans. Sisacaste the cylinder head is not much that you can see unplugged.
15 years 1 month before #13233 by manual-mecanica
Manual-Mecanica response on the Re: Audi Coupe already gives spark.
The problem was at the point of the Coin that as you can move, I did not have a Justo on the site and I had to move it a pelin but I did not send me a spark, I suppose it will be because it did not mark well with respect to the crankshaft sensors, but in the end I start, but I continue with the antigüo problem, in cold it stops, if someone turns on the bulb ... it is a 2000c 20v 20v 20v -type engine. electronics. Thank you
15 years 1 month before #13236 by manual-mecanica
Thus thought of changing the spark plugs
15 years 1 month before #13254 by manual-mecanica
I have already changed them, it is only hot cold slowly.
