I have a problem with my terrain 2 It is the model that is identical to the Ford Maveric it turns out that they are fixed do not intermittee any side or the emergency they are on I have tried I have tried that of everything
but it still does not work I went to a trace of SUVs and it is for the relays of where the fuses are The emergency switch and nothing remains the same
would appreciate if someone could lend a hand
I have also been looking for an electrical manual of terrano 2 but without success
I recommend that you try by changing the flash I think that is your problem it heats up and does not let go, it leaves the lights this flash is like a relay but it fulfills another function, check it this half hidden is not in the rifle or under the chest, it is a little more involved as below the bowl follows the noise it makes and you will aller, luck and let us know.
