Opel Vectra does not start
15 years 1 month before #13215 by manual-mecanica
Opel Vectra does not start published by Manual-Mecanica
I have an Opel Vectra Motor 20DTH I change the injection pump and it does not start it can be something else
15 years 1 month before #13230 by manual-mecanica
Manual-Mecanica response on the Re: Opel Vectra does not start
Did you change the injection pump because? Is it a oil tanker or bencinero? If it is a petroleum, you have to see the system if it is defeatiners you have to check that the bomb orrin that goes in the base is not spoiled a scratch and dies, especially if you put it without fat or culellina.
15 years 1 month before #13243 by manual-mecanica
I changed it because the diesel was wrong, it was very dirty so much that it seemed like oil, I am purging it with the denyarranque engine because it does not wear primer but nothing takes a long time to purge? or I have to change the Iguctors because it was standing like 7 months
15 years 1 month before #13251 by manual-mecanica
If the pump is electric, just put it in touch several times but buy an old gasolero gorger that is like a bladder and engineering to connect it and purge it once again disconnect it, connect everything how it goes and give it start
