Well friends, I have a problem with my pandita and it is that it starts three spark plugs but it is on the spark plug cable of the first cylinder the car is falling apart and although accelerates do not take revolutions to the
Hello ... are we going to prompt a couple of little things first? Change the spark plug and ax cable example the 2 cylinder and fix if you do it in that. 2. If you follow the problem with the first cylinder, detail what you do. counter -explosions? did you cause all the spark plugs and cables? ... We continue cominicated greetings
Well what happens to you, you throw three spark plugs and start well? And when you are accelerating the cable of the first spark plug the car falls down even if you have the gas in the table does not rise for revolutions and it seems that it went to two spark plugs then I do not know that I have to do this bug
