Greetings Members My problem is the following the Lelgo truck to my workshop with the very low brakes, after checking Booster and checking that there is no failure in the procedure to purge the brakes, and I did not upload anything to the pedal, I killed the client to replace the brake fluid since it was quite degraded (green).
He brought me again the truck and according to the manual review the conditions of the master cylinder, replace it already CEBE, and purge the system again, and nothing the pedal remains the same.
Does anyone else know what can I do to have a pressured brakes? I need to do something else? I need to keep purging the system until you have a pressure?
I hope someone can help me because I have no experience in these trucks and this had never happened to me, an acquaintance told me that it happened to him the same and that I purged enough until the desired result will be true?
I await your answers thanks
