nanual of na 20 (s)
15 years 1 month before #13540 by manual-mecanica
Nanual de Na 20 (s) published by Manual-Mecanica
My greetings Coordiales Mechanic Resiban I have a problem to the workshop, a D21 Nissan truck arrived on the body of the bodybuilder says that it is from the year 98 the strange thing is that it has a Na20 engine (s) (carburado) is mounted on the D21 truck. I arrive at the workshop in crane. Mechanical friends I need your help to start the engine repair of this truck. Thanking your help, I thank you waiting for your answer.
15 years 1 month before #13541 by manual-mecanica
Manual-Mecanica response on the re: nanual of Na 20 (s)
Friend no problem in helping you but what you need to know, what doubt you have, you want the engine to adapt it, because it was done to lose the compu here in Chile is done a lot about that in the rovers, tell us that you need saver to help you.
15 years 1 month before #13543 by manual-mecanica
Thank you mechanical friends for the answer, what I need is the engine repair manual (Service) If possible full manual is that this road arrived in non -operational motor crane, without a distributor, the transmission box arrived with nothing inside only Caracasa as they say I have arta chamba does not have a radiator etc. That is why I need the repair manual beforehand I thank the answer
15 years 1 month before #13558 by manual-mecanica
I moved your post towards manual request will be easier to find or help you.
15 years 1 month before #13559 by manual-mecanica
Did you already check the manual section? Test in ATP is a manual page.
