Failure in Skoda control box..Ayudaa !!
14 years 7 months before - 14 years 7 months before #17003 by manual-mecanica
Failure in Skoda control box..Ayudaa !! Posted by manual-mecanica
Hello good ... I have a Skoda Fabia 1.4 gasoline and the control picture has become Loko ... all the needles mark badly and all the failures are lit .... the car works well the engine too ... I do not know .. Can someone help me?
Latest edition: 14 years 7 months before by .
14 years 7 months before #17021 by manual-mecanica
Manual-Mecanica Response on the Re: Failure in Skoda Mandos Table..Ayudaa !!
You have a Massa lack -Hola, I'm Alex
14 years 7 months before #17030 by manual-mecanica
In the Octavias a small resistance is usually burned that is behind the control box, I do not know if in the Fabia it is the same, you can nirar it, before you have to take the picture.
All the best;)
14 years 7 months before #17039 by manual-mecanica
If none of that works you, you will have to take it to a good mechanical workshop unless you have a scanner that supports the Skoda brand with the scanner one connects to the computer of the car and erases the failures with that it would From the polo of La Vateria but I do not remember asking for there is only tereum that is the compu and it is necessary to take it to a mechanical taaler that is serious
9 years 1 month before #51054 by manual-mecanica
Manual-Mecanica Answer on the topic failure in Skoda Mandos Table..Ayudaa !!
Hello. Good, do I have the same problem in a Skoda Fabia 1.4 I of 2002.
Have you found the problem? It is not the safe picture since I have tried 2 and does it equally.
Please, if you have given the error, could you say it?
Thank you so much. I am already desperate
