Opel Astra Cambit Turn 1994
14 years 3 months before #19714 by manual-mecanica
1994 Opel Astra camshaft published by Manual-Mecanica
Hello, I would like to know if the camshaft of the Opel Astra 1994 1.4 Multipunto carries a letter g or an F because it had a camshaft with lyrics F and the mechanic tells me that it is not the one that carries the car that actually carries a tree with letter g, as rectified the engine I do not know if they changed that auto or really carries with letter F.
9 years 1 month before #51025 by manual-mecanica
Manual-Mecanica response on the Opel Astra cams shift 1994
Hello good afternoon, I am new in the forum and I have the same problem you raised about the camshaft, I wanted to consult if you could find out what the camshaft that carries the car was
9 years 1 month before #51044 by manual-mecanica
and some of those changed and being the same height of the cam and having the same lubrication heads should not be a problem
