Map Wagon R sensor
14 years 3 months before #20167 by manual-mecanica
Manual-Mecanica Answer on the Re: Map Wagon R Sensor
Hello, these measurements are very rare all ECUS work with sources of 5 volts for both them and for signal processing, this is because they are constituted by CMOS circuits in the most. In these three lines of the sensor, 5 volts, 0 volts or dough and the return signal that must be measured with the sensor connected to preference with an oscilloscope and apply empty to the sensor should be seen in any case and see how the signal changes. If you perform the measurement with the sensor disconnected in the signal line will see 5 volts because that line within the ECU is linked to a voltage divisor that the ECU uses precisely to diagnose the sensor. Through this voltage divisor the ECU puts 5 volts to that line. You may not understand what I am talking about but that is the normal form of operation of all the ecus that I know. At least I don't know any MAP who works with 12 volts if someone knows him that corrects me, maf sensor "yes" but map no, and that car has only Map. I recommend that you talk to your mechanic and check the multimeter scale if it is measuring with it, to reconfir those measurements but those readings are not well. If those measurements are correct within the ECU there must be any safe damage. I am attentive to your comments greetings.
14 years 3 months before #20168 by manual-mecanica
Ahh By the way I am also from Venezuela greetings!
14 years 3 months before #20172 by manual-mecanica
Hello, thank you really
all this story with my car, it began when it occurred to me to wash the engine (according to the mechanic), because everything was moo ... I already changed the rotor, the distributor of the distributor, the coil repair some cold welds on the computer I change the sensor of electriquela power pump etc. Scaner and gave the verdict that you already know .. the problem in addition to economic since they are super expensive spare parts .. it is difficult to find them ...
hopefully we can adapt the Map Toyota (I think yes). And lighting
it really for all your comments (better than those of the mechanic)
is complicated here since we are in Margarita
your living in Venezuela?
Greetings
14 years 2 months before #20175 by manual-mecanica
Hello, if I am from Venezuela and I also live in Margarita, I am recently silent, I do not have a workshop yet, work at home of workshops such as MAG and Euphoria Performance. My tlf num by Digitel is 2776575 My name is Antonio, if you want and cannot turn on the car you call me and we agree. Greetings
14 years 2 months before #20181 by manual-mecanica
Gracas sure yes
