Low lubrication in 5.3 vortec engine of silverado
14 years 1 month before #21787 by manual-mecanica
Manual-Mecanica response on the Re: Low Lubrication in Silverado Vortec Motor
Good afternoon my fried corduroy? If you are in Venezuela or why I see that you are mechanical and you know very well the 5.3 engine I am interested in doing that job how much would I charge me I have a small blacksmith workshop where it can be done in case you have no workshop !!! My phone is 0414 2332722 I am in Caracas anyway thanks for the information
13 years 5 months before #30424 by manual-mecanica
Hello fried I have an avalanche 2007 and I have the problem I mark me low oil pressure, Stabilitrak, I do not know how to fix it I already have the new sensor in which part of the engine carries the sensor?
13 years 5 months before #30434 by manual-mecanica
Hello cars, your problem is not in the sensor, your problem is the urine of the oil collector that is already bad and you have to lower the carter and take out the collector you change the orin and but before mounting that orin you place one more thin one of the same size and then you mount the original orin of the same thickness and you move everything and you have solved your problem. I hope my help serves you
13 years 5 months before #30461 by manual-mecanica
The engine sounds a lot a cold pointer but when it is heated a little stop sounding but sometimes when it has a long time working it sounds like this it is because of the same problem of oil pressure or that could be
thanks for the previous council
13 years 5 months before #30468 by manual-mecanica
If this is therefore these engines carry tacks on rolines and work on the lift tree
