XSARA ELECTRIC PROBLEM 1600 GASOLINA
13 years 11 months before #23103 by manual-mecanica
XSARA ELECTRIC PROBLEM 1600 gasoline published by Manual-Mecanica
I have a Citroen Xsara 1600 gasoline year 2002 for a long time I have not ignited the population light and the flashing light in the painting but they do not do it in any pilot or the emergency or the normal ones, apart from the remote control to open the doors I stop working when changing the battery, and I have not been able to subtract it, it will be the BSI, or the control controls will be diagnosis and do not find the fault. Thank you for your answers
13 years 11 months before #23104 by manual-mecanica
Manual-Mecanica Response on the Re: Electric Problem XSARA 1600 Gasoline
Hello,
it is very likely that it is the BSI, lately they are giving many failures, I have many cases, in some only resetting with the SH Shunt fuse under the dashboard, it was solved, quitalo in the same port of Fusible there is another pin places a fuse of 30 amp puts the contact you will see that the information is erased, take the contact again and place the SH in its place. issues
13 years 11 months before #23142 by manual-mecanica
It is true here in Chile, the BCI only give problems, the failures begin with the theme of the intermittent and then progress
13 years 11 months before #23149 by manual-mecanica
I will ask an equal case and I will comment on it.
10 years 3 months before #48774 by manual-mecanica
Manual-Mecanica Response on the Electric Problem Theme XSARA 1600 Gasoline
Hello, I have the same problem, have you to solve it?
