Problem in the game hiunday accent `98
17 years 3 months before #2364 by manual-mecanica
Problem in the game hiunday accent `98 published by manual-mecanica
Hello friends, I have the next problem, every time the vehicle (Hiunday Accent) is a couple of hours, when it gives it it costs a world that starts, but then that part and if I stop as many times as part without any problem, the problem only occurs when it is a long time stopped. They tell me that the following elements can be failing: detonation sensor, fuel pressure regulator, fuel pump. What will it be?
I hope you can help me, thanks :(
17 years 3 months before #2377 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem in the game hiunday accent `98
Convenient to measure press combustivel na time of sharing or engine and conferred with manufacturer.
Power tamm being deficiency of temperature sensor do motor, no case measure !!!! resistance x temperature !!!! and confer com Tabela do manufacturer of the veículo.
17 years 3 months before #2384 by manual-mecanica
FRIEND THE MOST POSSIBLE THAT IS PASSING IS THE THEMERATURE SENSOR ME
17 years 3 months before #2586 by manual-mecanica
You must measure fuel pressure, or it can also be the pressure regulator ..
