Hello everyone. I am new in this forum, and I need your help. I hope to help you also in your consultations.
I have a Peugeot Partner, which becomes like a Citroen Partner. The problem is in the instrument picture. This, snacks leads, the gasoline indicator is lowered and the reserve light is turned on, sometimes at the same time the oil, battery and hand brake light is turned on together, or stop working the velocimeter. Sometimes he does everything at the same time, sometimes they are sometimes and sometimes it is fine.
The picture is electronic, and I do not think it is the aforerator for the problem of the diesel indicator, because these failures began at the same time. He does not always, but sometimes.
Any help? thank you.
