Low light does not work
17 years 3 months before #2473 by manual-mecanica
Low light does not work published by Manual-Mecanica
Hello, I wanted to consult if someone had or knows about my problem that is the SGTE: I have a VW Polo 98 to which the low -side light is not working on the left side, just the high on that side and on the right side are perfectly the two of the two and the discharge ... it is testing it to see if it was not a fuse, a relay or a cable but so far I could not detect it The 12V should reach the cable so that the Pin of the Low does not arrive but already review and check and I do not find the problem, I repeat is not fuse or relay or cables ... Of course thank you for your help!
17 years 3 months before #2494 by manual-mecanica
Manual-Mecanica response on the Re: Low Light: It does not work
Have you looked if the bulb has the filament of melted shorts and that's why it does not turn on? It seems nonsense but you may have one of the two molten beams and that is why it only works in long.
All the best.
17 years 3 months before #2529 by manual-mecanica
Hello, the bulb test was the first that you also test in the tests use a new so that it is not that ... thanks the same
17 years 3 months before #2584 by manual-mecanica
Hello, personally, apart from relays, bulbs and other components, Miraria if you have current output from the control from which you put the lights, which can give that failure that you explain, they also usually fail.
All the best
