Gasail does not arrive at the filter
17 years 3 months before #2528 by manual-mecanica
Gasail does not reach the filter published by Manual-Mecanica
Hello everyone. I have a small problem with my 106 1.5D does not reach diesel to the fuel filter ceiling it manually.The pipes are not clogged since if the air is breathing it reaches the fuel deposit. Oh the primer changed it in case it was wrong and remains in them. That I can do. Thank you very much.
17 years 3 months before #2536 by manual-mecanica
Manual-Mecanica response on the Re: diesel does not reach the filter
Hello.
In this aspect I have found a case in which the diesel feeding tube that leaves the deposit of the deposit, was cracked, so the diesel did not even arrive to the primer.
If I remember correctly, on the trunk floor you should keep a record to access the tubes, if it is not accessed under the car.
All the best.
17 years 3 months before #2572 by manual-mecanica
To make sure that it is the diesel tube, apart from looking if you have any cracked or disconnected tube in the tank, you can place a tube from the diesel filter entrance to a carafe that you have with 5 liters of diesel on the ground.
In this way you are discarding the entire fuel line that you can not see, when you are prowned with the pear, the gasoleum should climb the tube, fill the filter and others, and if it does not go up it is that you have the diesel filter badly or that you have an air intake in the same filter.
So you save disassemble the deposit registration without being sure.
I have used this in a \ "Forito \" in an escort of the 98 that started, and the second stopped, (empty circuit) and no matter how much I looked and looked I did not see the diesel for any place until I realized that the diesel filter was touching my noses, air entered and the diesel returned to the tank when I was stopped for a long time.
Greetings (every teacher ...)
17 years 2 months before #2624 by manual-mecanica
Thank you for the contributions you have given me. The problem I had is that I take air for a toric joint that carries the container where the filter goes on a side, wears a screw put predation with a small filter and some toric joints.
