KIA PICANTO AUTOMATIC TRANSMISSION 2008
13 years 9 months before #25462 by manual-mecanica
Automatic transmission of Kia Picanto 2008 published by Manual-Mecanica
My automatic transmission of Kia Picantont 2008 when he warms it stays in the third change is slow on the output already changes the oil and filter and follows the evil and necessary to know what is the position of Seleneoid B in the body of valves that according to the diagnosis of the computer is what is damaged
13 years 9 months before #25516 by manual-mecanica
Manual-Mecanica Response on the Re: Automatic Transmission of Kia Picanto 2008
When they give solenoid code, the transmissions are blocked, if you do not know what the solenoid is you will try it to know what is the easiest is to erase codes and disconnect 1x1 until you know which one gives that code then when the solenoid is proven. If you give you solenoid B, the safest thing is that A is the same, you can exchange them to try if the code changes to know if your problem is the solenoid.
11 years 7 months before #43682 by manual-mecanica
Manual-Mecanica Response on the topic Transmission Automatic Kia Picanto 2008
Good my friend happened to me the same thing with my Picanto Mod 2008 and the codogos that the scanner gave me were P0743 and P0713 with these codes the car when it warmed it stays in third what was changed was the internal armor where the internal temperature sensor goes and the referral is 4630823000 original kia and I take off that problem that problem
7 years 9 months before #52588 by manual-mecanica
Hello, I have exactly the same problem and several mechanics do not know that it is the scanner throws the error P0743 I would thank you if you tell me more about this, where the spare is going it is easy to do so to do a mechanic or it is time to take it to the Kia workshop, thank you very much for answering I know that the post is a bit old
