Thanks for answering.
I take out the connector from thermorers that are two cables, one yellow and one white. If the Puentuo does not work the fan. The fan works, if I make a bridge of the relay cable that is near the expansion deposit, because two cables arrive, one red with the 12 volts and another brown, which leads to mass, acion the relay and therefore the fan works. This cable is the one that I think will go to an electronic circuit that is the one that does not know where it is, because if of thermorers, two cables, yellow and white and the relay come out and the relay arrives, red and brown, where do the colors change.
I thank you again, and I hope your answer.
Greetings. Manuel Lopéz.
