greetings.
The problem is as follows, I have a 2004 Adventure Palio when the engine is hot begins to fail, even when I accelerate the engine tends to die (the current will be cut) and when it does not go out it stops that only three cyclnders work, because it fits a lot, and the focus Engine focus on (only when it fails) since when you turn off and turn on the engine, the problem correct by itself).
The last service was done at the agency at 60 thousand (now it is 64mil) and verify the spark plugs and cables and seem to work well, (I did the test of disconnecting cable by cable when it is failing and there was no change)
please I appreciate all the help possible, thanks thanks
