Corolla Fielder Diesel '01 Motor 3-CE
17 years 2 months before #2644 by manual-mecanica
Corolla Fielder Diesel '01 Motor 3-Co published by Manual-Mecanica
My car is giving a fault code described below:
P1225 4645 1225 Elevation Elevation Sensor Injector Needle
, I immediately turn it on and at the same time it fails again.
The code was determined with a scanner launch X-431. I need help, or some manual to guide me about it and try to solve the problem.
Thanks in advance.
Oliver
Dominican Republic
17 years 2 months before #2655 by manual-mecanica
Manual-Mecanica Answer on the Re: Corolla Fielder Diesel '01 Motor 3-CE
Hello, that code is that an interference is being closed is not without when that plothem fits if the engine starts ah bone for the side
17 years 2 months before #2668 by manual-mecanica
This engine model carries piloted injectors, that is, the switchboard receives information continuously from the exact moment of the injection and duration of the same, in order to make the necessary corrections on the injection pump.
The fault code is referring to the piezoelectric sensor located inside the injector or the electric connection of the engine sensor.
If that ruling appears during the operation, the fault light comes on and the switchboard enters \ "recovery \" mode so you can take it to the workshop.
The solution, change the injector piloted to one repaired or new.
All the best.
17 years 2 months before #2672 by manual-mecanica
Thank you so much.
17 years 2 months before #2673 by manual-mecanica
Thank you very much for the help.
Greetings.
