Hello everyone. The battery is downloaded
17 years 2 months before #2675 by manual-mecanica
Manual-Mecanica response on the Re: hello to all. The battery is downloaded
Ok Elisa for me was a great rear to you, we are at the order, a Apraco, (Miguel)
17 years 1 month before #3062 by manual-mecanica
With a simple trial lamp pen disconnect a battery pole with the switch off connects this to the battery pole and the other part to the disconnected cable if it turns on is that something is being left on but it can be the regulator of the alternator OK
17 years 4 weeks before #3285 by manual-mecanica
Incredible but true, once it happened to me, it was the radio that was turned off but it was not turning on the things of electricity
17 years 4 weeks before #3288 by manual-mecanica
Hey Elisa As you hope well, first check whether the alternator belt is lavast I should not make any spark between the pole and the terminal check and do these controls and let me know I greet you Alf.-
17 years 23 hours before #3575 by manual-mecanica
The Peugeot 309 happened to me, in the end it was a cable that was released and roxaba in a sheet, anyway I checked the alternator
