Motor replacement 98 by one of the year 2002 2.0
17 years 2 months before #2714 by manual-mecanica
Neon 98 motor replacement of 2002 2.0 published by Manual-Mecanica
Dear friends I have a neon year 98 which replaces the engine for one of the year 2002 and I do not turn on the only thing that changes in the new engine is the little sensor of the craniñal sensor the rest is the same
there is some way that can make it work without having to replace the computer and the cable branch that according to some mechanics tell me what I have to change .... help I stay without money without money
17 years 2 months before #2715 by manual-mecanica
Hello good night. Contain me you passed the scanner if you do not pass it on layers, it is not fascinating so if it is the same module by the position of the sensors I do not design anything, the interferes do not know with the withpativle, anything you tell me ok a Apro
17 years 2 months before #2716 by manual-mecanica
Brother thank you very much for answering I spent the scanner but and tried to turn on and it seems that it would be out of time throws the splation for the carburetor and with respect to the injectors I put those of the engine of 98 that stopped to those of 2002
