Help Problem with New Box 2002
17 years 2 months before #2752 by manual-mecanica
Help Problem with Neon Box 2002 Published by Manual-Mecanica
Hello, how are I need help, I have an automatic neon 2002, and when I turn it in the mornings, the box does not change it I have to roll at least 15 minutes, then I turn it off I leave it so 5 minutes and when I turn it on again the box works perfectly until the car cools. I have taken it to several workshops and each one tells me that it is a different fault, if someone in this forum can help me or guide me with this thanks
17 years 2 months before #2760 by manual-mecanica
Manual-Mecanica Response on the Re: Help Problem with Neon Box 2002
Hello, send the converter to review, because that defend is weird if you say that you do not enter any velocid
17 years 2 months before #2765 by manual-mecanica
Thanks Maat, they tell me that it is something electric since when the car turns off and leave it 5 minutes and turn it on again the box works perfectly. Thanks for your help, I'm going to review it
17 years 1 month before #3063 by manual-mecanica
I suppose your box is electric in Czech your solenoid box that is next to the transmission or the input or output sensor?
