temperature problem
17 years 1 month before #2906 by manual-mecanica
Temperature problem posted by manual-mecanica
Hello estimates, I have a Nissa Sentra 2 year 96 which has something very rare when I turn it on the indicator of the TºUBE normal, but when I in order to walk the indicator of the taº dema demacious (low everything) they have told me many things that it can be but I do not know which one to believe. If I could help me, I would be very appreciated.
17 years 1 month before #2929 by manual-mecanica
Manual-Mecanica Response on the Re: Temperature problem
Hello good night if I do not equibo your car does not have thermotatic valve, that so that the car raises the wind when the wind that is recovers to fly the radiator's tennencle, I hope to break you.
17 years 1 month before #2947 by manual-mecanica
The thermostat that stayed open and does not do its job of maintaining a constant temperature in the engine something else if you are traffic that makes me know greetings Alf.-
17 years 1 month before #2968 by manual-mecanica
In your case it would be good to say if you consume water, in bad cases that the water goes to the engine.
I have a question in my case, with a seat gasoline 1.4 97, the temperature needle is only in the middle, when I start the air the fan is left all the time running, lowers the temperature a little but not much, the lid is good and the clean site the thermostat opens but why will it be hotter?
17 years 1 month before #2971 by manual-mecanica
Hello, how are I new in the forum I have a subaru legacy of the year1992 and I had to do a vaipas because the canopy of heating (the one that goes out down by Delante) is broken Frio that is sometimes
I think it may be that the radiator is covered, do you think it can be? Thank you, I think this page is spectacular for us nuts
