temperature problem
17 years 1 month before #2972 by manual-mecanica
Manual-Mecanica Response on the Re: Temperature problem
Hello, how are I new in the forum I have a subaru legacy of the year1992 and I had to do a vaipas because the canopy of heating (the one that goes out down by Delante) is broken Frio that is sometimes
I think it may be that the radiator is covered, do you think it can be? Thank you, I think this page is spectacular for us nuts
17 years 1 month before #2975 by manual-mecanica
Not the fan is activated since the cars have a valve called Trynary that makes the compressor fucion up and there is gas and to start the fan when the pressure of the high line increases there are cars that are kept all the time on since the high pressure is or has to be constant and that the temperature is lowered a bit
17 years 1 month before #2976 by manual-mecanica
If you eliminated the heating radiator that hot air you want it to come out and the water goes to what temperature the engine fan starts.
17 years 1 month before #3060 by manual-mecanica
Send your radiator and Czech the thermostat is probably not letting the water pass as if the Czech problem follows that your pump is sending the appropriate press
