Ford Explorer 92, presence of blue smoke
17 years 1 month before #3003 by manual-mecanica
Ford Explorer 92, presence of blue smoke published by Manual-Mecanica
Hello colleagues, I have put into practice many of their advice and I have been solved by the problems that have been presented to me, if they were so friendly to help me with this specific problem that I have, in the morning when my explorer comes out abundant blue smoke and the idle is unstable, I have not yet measured compression, but if it were the case of repairing the engine the specifications of the explorer 99 beforehand.
17 years 1 month before #3008 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Explorer 92, presence of blue smoke
Probably the problem of idle has to do with the iAC Ipr Ipri air contol 6248 New York
17 years 1 month before #3026 by manual-mecanica
Hello, your car is automatic or manual change, you have controlled if you have any engine consumption both engine or speed box if it is automatic
17 years 1 month before #3058 by manual-mecanica
I agree with Tavogus your problem should be excess fuel since your blue smoke indicates, if it were black it would be oil if it was white it would be water so that your problem is fuel of more
17 years 1 month before #3103 by manual-mecanica
Thanks for your answers, they have served me a lot and I have solved the problem by replacing the IAC
