Fair pilots come on.
17 years 1 month before #3035 by manual-mecanica
Fair pilots come on. Posted by manual-mecanica
Hello.
I have a 19 diesel renaul and in relief, all the pilots are lit, which indicates in the painting, as before starting. When they accelerate, they turn off again. Could you tell me where is the breakdown from?
Thank you. Sincerely. Manuel Lopez.
17 years 1 month before #3050 by manual-mecanica
Manual-Mecanica response on the Re: the damage pilots are lit.
Check the alternator as much as
you may have a burned and minimal diode do not charge you and the dashboard lights you
17 years 1 month before #3051 by manual-mecanica
That if the minimum is always the same and the engine has not dropped
17 years 1 month before #3052 by manual-mecanica
Hello. The release is the same, a little high, but it has not come down.
I had not occurred to me, but now, if I think that is the breakdown. I will tell you, because I am an electrician and tomorrow I check it.
Thank you for everything and I am very grateful.
Greetings. Manuel Lopez.
16 years 10 months before #4032 by manual-mecanica
Well, it is not from the alternator, because I have changed it for another that goes perfectly and continues with the same fault. When it heats up a lot, they no longer go out. The three pilots that are lit when heated, (about 10 minutes) are: the oil, the pressure and level and the temperature. The temperature goes perfectly, does not heat the cohe, only normal.
