Hello my problem is this:
I have an H100 that since I bought it fails when starting
and even at its optimal temperature it fails to the start as if it were carburetor I have to keep it accelerated a little for 1 min later it is removed and it is working well as I repeat this procedure I do it even with the hot engine I need its help to find the fault since my scanner does not read this engine
